Go to Post FIRST doesn't graduate you from HS ... your performance in class (your grades) do. - Franchesca [more]
Unread 17-02-2004, 13:21
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Using ground stem for power distribution
I'm currently using the ground stem as a power distribution - I have a bunch of connectors bolted on. It is properly insulated, very small chance of anything going wrong. It does not touch the robot frame, etc. Is this legal? I am using it in place of the power distribution brick, as it is smaller, lighter, and can use the right size wiring. I see no problems, but I wanted to check. Also, people keep saying that you must adhere to the power distribution chart. The way I read the rules is that this is a suggestion, not absolute law. What's the ruling on this?
Thanks,
Steven
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Ground Stud Teedoff101 Electrical 11 16-02-2004 07:20
Choosing a Linux distribution Robby Chit-Chat 8 03-01-2004 23:02
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
