Go to Post Every now and then, the judicious application of a modicum of common sense can make all the difference in the world. - dlavery [more]
Unread 17-02-2004, 16:01
tml240's Avatar
tml240 tml240 is offline
bahh
tml240 is on a distinguished road
sample limit switch code???
anyone got one???
we need it to program our arm
OHL 2004- ultimate NHL 2004 MOD
Unread 17-02-2004, 16:09
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: sample limit switch code???
Im pretty sure the default code already has PWMs and relay outputs that are programmed to stop if certain digital input pins are pulled low by an external switch.
From the top of my head, I think relay out 8 is tied to digital input 16? intended to be used with the compressor and the pressure limit switch? - that would be a good example of how to start.
Unread 17-02-2004, 16:17
tml240's Avatar
bahh
we are trying to use limit switch as interrupts... and when the arm hits the switch, it will stop moving, that's our plan
Unread 17-02-2004, 16:26
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
then you would probably need a single-edge based interrupt pin to determine when the circuit goes from open to closed.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 17-02-2004, 17:10
it would be much simpler to have the line of code that is controlling the motor also look at the limit switch on a digital input pin, instead of using interrupts
this is not really an interrupt application, because you are controlling the motor output on every loop of your code anyway, there is no reason to interrupt the loop when the switch closes - the victors and spikes dont respond that fast.
besides, contact switches bounce when they open and close - which means, instead of simply going from 0 to 1, they go 0000111110011011010101111111111 - so for every switch closure you will see maybe 20 to 100 interrupts within several milliseconds.
Unread 17-02-2004, 17:13
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
As Ken mentioned, this section from the FRC default code, user_routines.c, Default_Routine() does what you want. Each of the pwm outputs are stopped by a limit switch in either direction (min, max).
Code:
  /*---------- PWM outputs Limited by Limit Switches  ------------------------*/
  Limit_Switch_Max(rc_dig_in05, &pwm03);
  Limit_Switch_Min(rc_dig_in06, &pwm03);
  Limit_Switch_Max(rc_dig_in07, &pwm04);
  Limit_Switch_Min(rc_dig_in08, &pwm04);
  Limit_Switch_Max(rc_dig_in09, &pwm09);
  Limit_Switch_Min(rc_dig_in10, &pwm09);
  Limit_Switch_Max(rc_dig_in11, &pwm10);
  Limit_Switch_Min(rc_dig_in12, &pwm10);
  Limit_Switch_Max(rc_dig_in13, &pwm11);
  Limit_Switch_Min(rc_dig_in14, &pwm11);
  Limit_Switch_Max(rc_dig_in15, &pwm12);
  Limit_Switch_Min(rc_dig_in16, &pwm12);
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
Some EDURobotics Problems squide Robotics Education and Curriculum 9 20-01-2004 10:27
I am wondering........... geo Technical Discussion 10 15-04-2002 13:17
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
