Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 17-02-2004, 17:29
alan koch alan koch is offline
alan koch is an unknown quantity at this point
navigate and default code newbie question
If we use the default code to run our robot, how do we incorporate navigate to run the ir sensors in autonomous mode?
If you can make it simple, I would appreciate it. I'm just a fabricator who got elected to program the bot.
Unread 17-02-2004, 18:27
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: navigate and default code newbie question
well, most of the code is contained in tracker.c and navigate.c - there shouldn't be too many modifications.
first, navigate uses pwms 3 and 4, whereas the default code uses 1 and 2 - you'll need to reconcile this.
second, the call to navigate should go in User_Autonomous_Code.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 17-02-2004, 22:25
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It was talked about here http://www.chiefdelphi.com/forums/showthread.php?t=216607.
In addition to those instructions you'll also need the navigate.c and navigate.h files, and you'll need to add a call to navigate() to the User_Autonomous_Code() routine in the user_routines_fast.c file.
navigate code AlphaOmega870 Programming 2 02-02-2004 18:54
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
