Traction trouble
This year, our drive train works great, except one small problem: We are using the skyway wheels from the kit, but it is way to easy to burn out in them. They don't get enough traction. Does anybody know of any wheels of similar size that have much better traction from skyway or other sources? We have 2 wheel skid steering so too turning will not be a problem. We have room to double up the wheels or use wider ones. Any suggestions? DO the black wheels get more traction? What about modifying non-pnumatic tires? Please help!
Re: Traction trouble
We are using pneumatic go-kart racing slicks again this year but upgrading to 12". If you are looking for traction these are superior. If you are looking to not cry when you put your robot on a scale find another source. They weigh like six pounds each. And we are using four in a four wheel drive skid steer setup. No one is pushing us off a six inch step...Unless we do it to ourselves. Lol.
If you are using skid-steer as in 2 wheels and 2 skids, your problem may be that you dont have enough weight on the drive wheels. If you can shift some weight over to them, you will get better traction.
What tire pressure are you using? Gearing? Be more specific and we'll see what we can advise.
Lemme elaborate James,
We have roughly 130 ft/lbs of torque per wheel, we move at a top speed of about 8 ft/sec. We have plenty of power, but we cannot get the power to the ground, we are doing burnouts and skidding on carpet. We are looking into other wheel options, we are looking at things like gokart slicks and solid urathane skyways. Thoughts? -Andy |
skyway sells a version of some of its pneumatic wheels where the air tube is replaced by a hard foam insert. they have excellent traction, but I'm not sure that you can get it with the big wheels (ours our only 6")
#10
Hey all, thanks for the input!
We are using two drive wheels with two skids on the rear. (we're using skids cuz we thought we wouldnt be able to skid stear-have had bad experiences in the past) Today I came up with a new concept. Put another set of drive wheels just behind the others. That way we have the best of three worlds: we have great traction, turning ability (because the wheels are close together), and we can drive in straight lines easier. Also it is narrower then the gokart slicks so that we can still drive up the stairs and make it around the goal. Try my poor ASCI drawings where () = wheel v = skid - = frame *current side view* ()-------v *proposed side wiew* ()-()----v This option would be very easy to add to our robot and would add only about 10 pounds of weight and it just so happens we have weight to spare. By the way, who is your supplier for the gokart slicks? I've had the hardest time finding them on the internet. Thanks! Thoughts? Opinions? Thanks -Andy Last edited by andy : 19-02-2004 at 23:00. Reason: spelling *sigh* |
#12
Its a local distributor but I am not sure where they get them from. It was all by accident last year too. We wanted knobby tires and after we ordered them we got the slicks back. But the worked great. I like your new idea a lot. We do have traction problems but we need the traction to get over the step. Good luck.
| Anyone else having trouble keeping up with work? | D. Gregory | General Forum | 36 | 28-03-2004 16:55 |
| Materials for traction | parteyboy10 | Rules/Strategy | 1 | 13-01-2003 21:15 |
| traction questions | AlbertW | Rules/Strategy | 2 | 05-01-2003 17:58 |
| Friction, traction, torque - oh my... | Gui Cavalcanti | Technical Discussion | 30 | 13-08-2002 18:01 |
| New Haven ball trouble | Jeff Rodriguez | Regional Competitions | 1 | 04-04-2002 21:47 |
