Go to Post A good teacher always needs to be a good student - Redhead Jokes [more]
Unread 18-02-2004, 00:12
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Help wiring Line sensors
Hi! guys I am in big trouble can any one please quicklly send me a picture of wiring a line sensor or a schematic of wiring a line sensor please. my e-mail is jigarjuhi@yahoo.ca
Unread 18-02-2004, 10:17
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Re: Help wiring Line sensors
This is how I wired them up for the FriarBot:
-The brown lead has to pull +12v through a breaker. (dont use the +5 output from the digital i/o ports, its not enough)
-The blue lead has to go to the ground pin on a digital i/o port.
-Either the black or white lead has to go to the signal pin on that io port. Only use either the black or white. The white lead is for "sourcing output" - the white lead will go high when the sensor "sees" the line. The black lead is for "sinking output" it will go low when the sensor "sees" the line.
-I used sinking output for our design, but i dont think that it really matters. Just remember that the sourcing output will register a logic 1 in the code, and the sinking registers a logic 0.
See this page for schematics http://www2.usfirst.org/2003comp/Spe...nersensors.pdf
Also, check out our team site at www.friarbot.com
Can anyone tell me the proper code for line sensors thelastride Programming 1 14-02-2004 13:47
Current sensors wiring zainali Electrical 5 13-02-2004 00:39
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
