Go to Post The most important part anyone can lend is just a hand. - Libby K [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 18-02-2004, 01:54
JamesWu JamesWu is offline
#0957 (WATSON)
JamesWu has a little shameless behaviour in the past
Question My file size is too big.....
I'm almost done with the animation....I know it's pretty fast to be done...But thats not the point. I had rendered everything in max in mov format and mpeg4 compression...Then i dl'd Premiere Pro Trial and loaded everything in with the slate and all. Then i rendered it again, and absolutly according to the specs...720*480, DV-NTSC, 29.97fps and .mov, so why is it that the file size is 261mB... Especially when they said to keep the file size well under 250 megs.
I want to start a revolution. Days and Nights were spent wrestling with the impossiblities of typing a word with only one finger. That word is lol, So....use laf.
Unread 18-02-2004, 08:10
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Re: My file size is too big.....
Here we go again. 2 years ago autodesk gave codec requrements that produced files that wont fit on a CD. (of course they changed it in team update). Similar things now....
Try emailing Autodesk?
Unread 18-02-2004, 08:20
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
hmmmm.....
this is a shot in the dark, last year we rendered un-compressed frames in Max. Then we went in an compressed them in premiere using the codec specifications we did last year. I think that you are running into problems b/c it has to compress twice. Have you rendered to still shots from max? If you do that output to a tiff (best quality). That is the only possible thing that I think could help you.
if u have to email autodesk put EMERGENCY in the title. They usually respond a little faster. Otherwise it will take 3-5 weeks to get a straight answer.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 18-02-2004, 08:30
Lev's Avatar
Lev Lev is offline
I just did some test renders, and 250mb seems a little high. I did moderately complex scene (color-distribution wise) and rendered 900 frame sequence - so far its been 115, and 105mb Is it premiere thats spitting out these huge files? or did max do same thing?
Unread 18-02-2004, 09:49
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
you should have rendered the original file out of max in the highest possible setting. I'm not sure cuz i havent used max... but it would probably be an uncompressed DV standard AVI. Then you could compress it in premiere (theres a tool in it that will size it automatically, all you have to do is give it guidelines such as frame size, and final size(under 250 mb's)) Trying to compress a compression just isnt going to work. Heres an example. Take a wav file of a song and compress it to mp3. Add this to a zip archive. Then take that original wav and do the same. You will see the pecentage each drops down is quite different. (I know this isnt what you are looking for, but it is just an example)
Unread 18-02-2004, 10:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Compressing a compression, I think, has different issues than are being discussed here. I can't see doing a lossy compression twice as actually increasing file size by a significant amount. However, doing lossy compression twice will definitely adversely affect the quality of the video.
So basically, I agree with most here. Render the animation as an uncompressed AVI, or a series of lossless compressed TIFs, then dump that into Premiere, edit what you want, and compress it from there. Premiere should give you enough options to fiddle with the compression quality and get it down to size. I wouldn't let premiere actually resize the video to get it to size though. Aside from the video resolution formatting requirements, resizing the video will, again, mess with the quality. If it absolutely has to be resized, render it again if you have time.
Also note, the plus about rendering to a series of TIFs is that you can grab a load of your teammates spare computers, network them, and do a network render over a weekend.
Unread 18-02-2004, 18:10
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
If you change your size to 640x480, the other acceptable size, your file size will be smaller.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 18-02-2004, 19:12
Lev's Avatar
Lev Lev is offline
This might not be an option if you designed all of your scenes with 720x480 in mind. Plus, 640x480 requires re-rendering, which at this point in time is kinda late.
Unread 18-02-2004, 19:37
Depending on how complex your scene is, maybe not. On the animation I did, it took nearly a week to get everything rendered out (Non-stop renderthon on four computers and it still took a good school-week to be done), so if you're like us, you'd basically be stuck with what you have. I think you can change the physical size of a file in Premiere though.
Unread 18-02-2004, 20:17
Lev's Avatar
Lev Lev is offline
right, so basically if you have complex scenes, and chose 720x480, you are screwed because of poor rule requirements.
Unread 18-02-2004, 21:42
#0957 (WATSON)
Well I found out why my file size was so huge....I rendered uncompressed in premiere. So I rerendered the final draft and it was 90megs and the quality was appalling. I think the bad quality is because of rendering in max as a .mov mpeg4 commpression. However, it puzzles me that the still images, placed in premiere, also have bad image quality. It should have good quality despite the twicecompressed 3d portions. Please reply to confirm this.
How big will FIRST ever get? Raul General Forum 41 26-10-2004 10:45
Goaltending- the next big controversy Wayne C. General Forum 69 23-01-2004 14:07
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Size of the field: too big? too small? archiver 2000 5 23-06-2002 22:44
A file size issue Funkymunkey90 3D Animation and Competition 2 05-02-2002 14:50
