Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 18-02-2004, 19:35
Zyre Asuka Zyre Asuka is offline
Zyre Asuka is an unknown quantity at this point
Question transducer
I know we need the pressure switch, but do you have to mount the transducer?
Unread 18-02-2004, 19:51
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Re: transducer
you don't have to have it I believe...you would just need to have it inline with the part of the circuit (pnuematic) that you want an exact pressure from at any given time.....you can read it out through the dashboard, or use it in your program....gl
Unread 18-02-2004, 20:02
Re: transducer
So I could leave it off compleatly?
Unread 18-02-2004, 20:14
Team311's Avatar
Team311 Team311 is offline
School Is Boring
#0311 (Red Jammers)
Team311 will become famous soon enough
Re: transducer
you might want to try looking in the pneumatics manual
Unread 18-02-2004, 20:25
Re: transducer
It just says it is for giving you a presure readout, it doesn't say if you need it or not.
Unread 18-02-2004, 23:39
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Re: transducer
We have left ours off. We don't plan to monitor the system pressure so it would be a waste to incorporate it.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 19-02-2004, 11:15
jjv jjv is offline
jjv is an unknown quantity at this point
Re: transducer
No, it isn't required, only optional if you want more control over your pressure. We (548) are using ours, and are looking to collect a few spares. If any of you that aren't using it would be willing to trade, let me know.
Thanks,
Josh
josh.vetter@us.bosch.com
Unread 19-02-2004, 11:58
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Re: transducer
We added the transducer yesterday. It was very easy, and I think it will give us much better control than the pressure switch.
I wasn't able to find any schematics for connecting it to the analog-in anywhere, but I guessed red-red, black-black, green-white and that seemed to work.
Eric.
Pressure transducer NoRemorse Pneumatics 2 14-01-2004 23:43
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
