Go to Post I don't even consider FIRST to be an extracurricular anymore; it is a way of life. - Jaine Perotti [more]
Unread 02-18-2004, 09:38 PM
Yellow Eyes's Avatar
Yellow Eyes Yellow Eyes is offline
Programmer
AKA: Brian Novak
#0250 (Dynamos)
Yellow Eyes is on a distinguished road
Send a message via AIM to Yellow Eyes Send a message via MSN to Yellow Eyes
Tracker Code
Does anyone have a working Tracker code that we could borrow to see if our IR Works. PM a link to it.
Sorry for asking, but our code did work...and now, it doesn't. We've plugged them into the right PWMs and the IR Beacons do work...and we've even talk to Kevin...from Kevin.org. It's getting very annoying.
Unread 02-19-2004, 09:35 AM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: Tracker Code
Hi Brian,
Last week, our IR receivers stopped working after we replaced a few cable connectors on the circuit board they were soldered to. We also had one stop working when we replaced the heatshrink we wrapped the receiver in.
We didn't feel we used excessive heat in either case, but when we scoped the signal pin of the IR receivers afterwards, we found that they were no longer pulling all the way down to 0V, but were floating around 2-3V instead.
-Shawn...
Unread 02-21-2004, 11:11 AM
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
Re: Tracker Code
Originally Posted by SlimBoJones
Hi Brian,
-Shawn...
The signal pins on the receiver shouldn't pull down to 0v if you're testing with the beacon code. One of the beacons will give you a voltage of 4.4 volts on the sensors and the other will give you around 3.9. This is due to your meter averaging the value received from the sensor over time.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 02-21-2004, 11:14 AM
Alpha Geek
Re: Tracker Code
http://www.chiefdelphi.com/forums/sh...ad.php?t=25576
What is your most prefered programming language? Hailfire Programming 156 01-19-2005 09:42 PM
Interrupt timer, executing code asap? SeanCassidy Programming 10 03-07-2004 01:47 AM
Operator Interface code RiotingNerd Programming 5 02-07-2004 09:13 PM
Inserting Naviagation code into Default code? actorindp Programming 3 01-28-2004 06:12 PM
Does your team use the Default code. Jeff McCune General Forum 2 01-09-2003 02:46 PM
