Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 19-02-2004, 13:49
blindguyinanorg's Avatar
blindguyinanorg blindguyinanorg is offline
Matt Spencer
AKA: Sexy Beast
#1007 (Team Generals)
blindguyinanorg has a little shameless behaviour in the past
Send a message via AIM to blindguyinanorg
cant get into autonomus
i followd the directions int the manual(set team # to 0 then untether) still getting no autonomus. what do i do, a program based autonomous would be nice so i can use dasboard
"No drugs, not even alcohol cause the fundementa ills of society. If we're looking for the sources of your troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, freed and love of power" - PJ O'Rourke
Unread 19-02-2004, 14:11
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
Re: cant get into autonomus
You could always make an autonoumous dongle. Then you could go into autonomous at the flip of a switch instead of setting the team # to zero all the time. Directions from Innovation First on how to build one are here Also the disable switch is a very useful safetey feature
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 19-02-2004, 15:01
hobbes hobbes is offline
hobbes is an unknown quantity at this point
are you sure you are not in autonomous mode? (check the disable light on the operator interface, if it is blinking yellow, the robot is in autonomous mode). it may be that you are in autonomous mode, but the robot does nothing. i had a similar problem ...... http://www.chiefdelphi.com/forums/sh...ad.php?t=24386
Unread 19-02-2004, 18:19
Matt Spencer
AKA: Sexy Beast
i know all the LEDs are blinking green
Unread 20-02-2004, 13:50
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
If you want to use dashboard, the best thing to do is to make the dongle. That way, if you see that something is seriously wrong or you want to kill the bot, you can bring it out of autonomous with the flick of a switch. You can also disable the bot using the same dongle. This is useful if your controler is out and people are bumping it, but you don't want to turn it off. Disableing kills all of the inputs from the OI.
Unread 20-02-2004, 13:58
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
actually, disabling does not kill any of the inputs, it just kills the outputs from the robot controller to any other device, such as PWMs, et cetera.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 20-02-2004, 14:44
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
On your OI you can set a trigger.
Code:
#define AUTO_BUTTON       p1_trig // don't quote me on the variable
if ((autonomous_mode =0 || AUTO_BUTTON = 1)
  // Execute autonomous code
(I don't have the exact code in front of me)
Then All you need to do is pull the trigger and your robot jumps into auton.
Release the trigger to stop it. (great for stopping a run-away robot )
Phil
Unread 20-02-2004, 17:06
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
I like port 3 for stuff like this: 1&2 for driving, 4 for a dial box, 3 for debug/advanced.
