Go to Post You have the right to remain silent. Anything you say can AND WILL be held against you (AND YOUR TEAM) in the court of public opinion. So choose what you do wisely. - Koko Ed [more]
Unread 19-02-2004, 20:03
quickie25's Avatar
quickie25 quickie25 is offline
quickie25 is an unknown quantity at this point
Front, Left Motors
Ok..We have solved the mysterious victor problem but another has cropped up. I guess that is the warrants of being a rookie team. Now our PWM 1 motor runs fine but we cannot get 2-4 to work. This might be a programming problem but I would like to get everyone's input.
Thanks in for everyone's help,
team 1380
alloy - a mixture containing two or more elements fused together...(ie. A Team)
Unread 19-02-2004, 20:19
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Front, Left Motors
if you download the default RC programmers guide from innovationfirst.com in the documents section it will tell you which joysticks and wheels are mapped to which PWM outputs - and some of them have limit switches associated with them
when all else fails, put the default code back in and use there input to pwm mapping whenever possible
BTW - would you mind taking a second and going back to your other thread and briefly post what you did to fix it? when someone searches the forum, and sees your problem, it would be nice to know what the solution turned out to be :c)
Unread 19-02-2004, 22:48
quickie25's Avatar
Thanks for the info, I will post the solution in my previoius thread.
Team 1380
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
