Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 19-02-2004, 21:26
bheller bheller is offline
AKA: Brandon Heller
#0931
bheller is on a distinguished road
Team 931 Omniwheels
Omniwheel Render
Omniwheel Picture
Click on the above links to both a render and actual picture of Team 931's new omniwheels. The outer plates were waterjetted and milled by a sponsor, but the rest was student-fabricated, including the shafts, hubs, spacers, and rollers. These wheels are a drop-in replacement for the 9" Skyway wheels. We used 60A durometer urethane for the rollers. It's extremely flexible stuff -a pain to machine but worth it due to the excellent traction. The weight of the robot actually deflects the profile of the rollers so much at the roller edges that the wheel profile very closely approximates a circle.
So we installed them on the robot the other day, and they worked _too_ well! Think about it - with an omniwheel you essentially have casters when the robot's turning. The rotational inertia causes the robot to keep spinning when you lay off the stick, just like casters, causing overshoot. We're pursuing a gyro (ADXRS series) to fix this. The robot turns MUCH faster now.
Many thanks go to the Technokats, whose Trick Wheel design inspired these wheels. At the end of the season, I'll post a White Paper on the design, with inventor files, .dxfs and bill of materials.
Whaddaya think?
Brandon Heller
Team 931 Mentor
Team 449 Alum
Last edited by bheller : 19-02-2004 at 21:28. Reason: added blurb about white paper
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
Shelf Life Of A Team Vin211 General Forum 21 07-01-2004 22:31
Info for starting a new team (again, I'm sure) archiver 2000 3 24-06-2002 00:24
What constitutes the "Best" team? archiver 1999 9 23-06-2002 22:16
why why why...? archiver 2001 34 23-06-2002 22:13
