Go to Post I was proud that there was no whining, no finger pointing and no complaining. - Vikesrock [more]
Unread 19-02-2004, 22:07
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Quick question, probably asked a thousand times...
WHY does FIRST insist on using oversized wires??? I mean, I can understand that FIRST doesn't want any wires to fail, but if you are using thicker wire than the leads on, say, the compressor, than the extension will not burn up, but the leads will. That's not avoidable. Also, why do you have to use 6 AWG wires after the 120 amp breaker? If you have enough power to melt a 6 AWG wire, then it will trip the breaker. PLEASE TELL ME WHY!!!!!
Off on a tangent,
Sparks333
Quick Newbie Question Gobiner Programming 5 16-12-2002 12:49
Quick Question archiver 2001 5 24-06-2002 00:08
Quick question about the ramp archiver 2001 1 23-06-2002 22:51
Quick question about the ramp archiver 2001 5 23-06-2002 22:45
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
