Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 19-02-2004, 23:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Using Accelerometer with '04 controller
I know nothing about programming but can you use an accelerometer to measure tilt with the 2004 control system? I know it can be done in PBASIC but I don't know about C. Don't you need to use trig functions? Thanks.
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Using part of last years EduRobot controller m0rph3us Robotics Education and Curriculum 0 05-12-2003 17:09
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
