Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 20-02-2004, 11:34
actorindp actorindp is offline
actorindp is on a distinguished road
Problems with interrupt timer
Hey all.
I'm using the Innovation First White Paper to try to figure out interrupt drive timers.
I think I've done what they've asked except when I goto complie I get the following errors:
C:\robotics\DEFAULT-CODE-NR\user_routines.c:162:Error [1105] symbol 'T1C0N' has not been defined
C:\robotics\DEFAULT-CODE-NR\user_routines.c:162:Error [1101] lvalue required
C:\robotics\DEFAULT-CODE-NR\user_routines.c:166:Error [1205] unknown member 'TMR1Ip' in '__tag_86'
C:\robotics\DEFAULT-CODE-NR\user_routines.c:166:Error [1131] type mismatch in assignment
This is what i added to User_Initialization after "Add any other initialization code here" -- Is there where I went wrong?
T1C0N = 0x30;
TMR1H = 0x85;
TMR1L = 0xED;
/* T1CONbits.TMR1ON = 1; */
IPR1bits.TMR1Ip = 0;
PIE1bits.TMR1IE = 1;
INTCONbits.GIEL = 1;
I commented out the start timer cause im starting it with the click of a button.
Thanks for your help!
-Nick
OH Man guys nevermind. After the post I realized I should check my typing next time. I had a zero in T1CON and also as you can see a lowercase P in IPR1bits
Thanks anyway! lol
Unread 20-02-2004, 16:59
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Problems with interrupt timer
C sucks that way, doesn't it?
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Interrupt Handlers and Variable Scope kaszeta Programming 2 14-02-2004 18:30
Easy interrupt setup steven114 Programming 3 04-02-2004 00:07
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
Joystick problems archiver 2001 3 24-06-2002 02:40
