Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 20-02-2004, 17:13
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
Would this mesh be legal?
My team has just been putting the final touches (gearboxes, frame, electronics...) on our robot, and we came across this mesh we wanted to use. It is pretty ridged (a little more than a plastic pop bottle), and has ~1cm holes in it. You can see this better in the pictures I have attached.
Do you think it would be legal?
Thanks
ID:	1883  Click image for larger version
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 20-02-2004, 17:26
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Re: Would this mesh be legal?
Is the material itself legal? By following the parts use flowchart, I would say yes. BUT your USE of the material also needs to be legal (e.g. if you are using the netting as a non-functional decoration, or as a basket to hold balls, etc. then there is no problem - but if you are using it to ensnare other robots then it would be illegal).
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 20-02-2004, 17:54
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Dave is right, the material itself is legal, as long as it does not entangle an other robots OR damage the playing field in any way.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 21-02-2004, 09:28
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
Thanks guys!
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
omniwheels on steel mesh mickjagger Technical Discussion 14 26-01-2003 22:45
Which wire mesh will be used? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
