Go to Post Life is totally random and there's nothing you can do to change that. - kristen [more]
Unread 21-02-2004, 14:42
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
GeneratePWMS
I'm trying to read in a PWM. How do I do this?
On the edubot, they have the "setup who control pwms" function that changes the pwm_mask variable in the tx_data struct, but what does this do for me? This variable exists in the FRC code, so I can change it there, but I don't understand how this gets me input since there is no place for pwm inputs in the rx_data structure.
Unread 21-02-2004, 14:46
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Re: GeneratePWMS
Why do you want to use a pwm as an input?
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Unread 21-02-2004, 16:55
Re: GeneratePWMS
some sensors allow I2C input or PWM input, and we don't have access to the I2C
Unread 21-02-2004, 18:44
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: GeneratePWMS
I believe that there are a few #define statements in one of the header file that change PWMs 13-16 to either IFI_PWM or USER_CCP. That might be what you're looking for...
Unread 21-02-2004, 20:13
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: GeneratePWMS
No, that's not it. The Setup_PWM_Output_Type() function is to set up the specifics of the PWM signal. if you don't use IFI_PWM for all 4, you have to set it up yourself (see comment in the default code). this is done in User_Initialization().
Unread 21-02-2004, 20:30
Re: GeneratePWMS
I think that that's what I was talking about, sorry, I didn't have the code in front of me...
Unread 23-02-2004, 23:26
Re: GeneratePWMS
Thanks guys. I found a way to do it. Took some experimenting, but here it is:
Run the sensor output into digital inputs 2 and 3. Have interupt on 2 for the rising edge and one for the falling edge. The first starts the timer, the second reads it out and scales it.
I haven't actually tried this - I'll probably fool with it post-build season, but I was just thinking ahead since my team doesn't let me touch the bot. Something about building it....
Unread 24-02-2004, 00:56
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
FRC #0254 (The Cheesy Poofs)
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: GeneratePWMS
You don't have to do it like that. Dig I/O pins 3-6 are interrupt on change, so just plug it into dig io pin 3 and when RBIF triggers check to see that it is indeed pin 3 that changed (since 3-6 all trigger the same flag). You can sense both rising and falling edges on the same pin.
Unread 24-02-2004, 01:05
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: GeneratePWMS
Just FYI, interrupts 1 and 2 can also exhibit this behavior if you flip the INTEDGx bit in the interrupt handler. As a starting point, I'd suggest using the code in receiver.c/.h because it pretty much does exactly what you need to do (pulse width discrimination). I'm not sure if it's usable (IFI may have wired-in a output buffer on the CCP pins), but you might also look into using the CCP Capture mode to do this.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
