Go to Post "So [you're] like battlebots" Standard answer: No -- it's better! - Roger [more]
Unread 21-02-2004, 14:56
kingpin3787 kingpin3787 is offline
kingpin3787 has a little shameless behaviour in the past
Question HELP US PLEASE?!?!(pressure switch code)
under which heading do we put the pressure switch code!!!!!!!!!!!!!!!!!?????????????!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
Unread 21-02-2004, 15:13
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Re: HELP US PLEASE?!?!(pressure switch code)
I think that you should put it in User_Routines.c under Default_Routine() . We didnt use pnuematics this year, so Im not sure, but thats where I would put it.
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Pressure switch code kingpin3787 General Forum 11 22-02-2004 21:52
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
Inserting Naviagation code into Default code? actorindp Programming 3 28-01-2004 18:12
I am wondering........... geo Technical Discussion 10 15-04-2002 13:17
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
