Go to Post Cheaters never win, winners never cheat. :) - Amanda Morrison [more]
Unread 21-02-2004, 15:03
GrahamS314's Avatar
GrahamS314 GrahamS314 is offline
FRC #0314 (Megatron Oracles)
GrahamS314 is an unknown quantity at this point
Send a message via AIM to GrahamS314
Question Drill Motor Clutch
We're having a problem keeping our the clutch in our drill motors from slipping. I recall that the drills from two seasons ago allowed for teams to directly remove the clutch, and was wondering if perchance the new drills have any sort of similar feature. Any help would be appreciated.
Unread 21-02-2004, 15:22
Carlo Carlo is offline
FRC #0365
Carlo has a spectacular aura aboutCarlo has a spectacular aura aboutCarlo has a spectacular aura about
Send a message via AIM to Carlo
Re: Drill Motor Clutch
Yes there is a way to remove the clutch. By removing the front portion of the gear box, you can get to the two pieces of the clutch which interact. These are two round disks, one with 5 planetaries in it, and the other which houses the odd shaped gear which goes onto the final output shaft. By soldering/welding these two plates together, you can take off the entire front clutch assembly. This is the asembly starting with the big plast black cover, and as well as the spring and retainers which go along with it.
If you need any help I may be able to take photos or explain better. Hope this helps somewhat.
Carlo
University of Delaware
Mechanical Engineering- 2009
Dupont Advanced Fiber Systems
Unread 22-02-2004, 01:05
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Check this paper in the White Papers section. It is a photo walk-through of the disassembly of the Bosch 3360 Gearbox. It will show you the parts that have to be modified to solve your problem.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Drill Motor + Gearbox + Breaker Problems sear_yoda Electrical 28 03-03-2004 20:03
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
