Bouncing turns
We just had our first practice with our bot running and when we try to turn it it bounces out of control.
It is four wheel drive and we used the wheels that came with the kit. Is there anyway to stop it from bouncing and make it turn smooth? |
Re: Bouncing turns
I am currently working with 406 and we had the same problem. In order to fix that problem we found that replacing the front tires with some that have a smooth surface will give you a nice smooth turn. |
Re: Bouncing turns
-Kevin |
Re: Bouncing turns
just like he pointed out.... get more pressure on your tire... about 35 psi. |
Re: Bouncing turns
there IS another option... shave down the wheels!! or mabye get some teflon and start wraping them...
Re: Bouncing turns
Yea, we noticed this problem back in week 2 durring our first trial run, we fixed it by putting casters on pnumatic cylinders. On carpet we are always in caster mode but when we climb or we are on the platform we are on awd mode.
Re: Bouncing turns
Re: Bouncing turns
Well, at the DC Scrimmage last Saturday, I saw quite alot of bots w/ this problem...
Luckily ours wasnt one... But anyway, the 12" pneumatics wheels seem to be used ALOT this year. Mainly, I would assume to climb the platform from the side, which based on last weekends results, isnt going to work quite as well as people would hope... We personally stick with our 8x2" wheels, spaced out 26" wide (roughly) I'm not too sure how to eliminate the issue. If you're not planning on going up the platform, try to get some smaller wheels with a little less traction. Or, you could make 2 big omni wheels for the front or back 2 tires of your bot using a bunch of smaller omnis. I would make sure your tire pressure is full though. That was an issue with a few of the 12" 4x4 bots... |
Re: Bouncing turns
someone posted earlier that they painted the back wheels with poly somthing or another. the robot will rotate around the front wheels because the back ones slip.
also with the tire pressure deflate the front ones and inflate the back ones. you want it to rotate around one wheel set and slide the other. we just stuck some casters on the back that come up when we are climbing the platform |
#10
Re: Bouncing turns
Somoene actually suggested using a wax type substance like armor-all on the tires? Would that work, or be legal?
#11
Re: Bouncing turns
there is another post about this(by me) but it ended up in the pnuematics section sence i said pnuematic wheels HA! http://www.chiefdelphi.com/forums/sh...ad.php?t=25061 |
#12
Re: Bouncing turns
The Schmoebots had this problem as well. They solved it by simply removing the tires on one end and running on the rims. There's a little bit of slip from the different diameters, but it doesn't seem to cause any problems.
#13
Re: Bouncing turns
or make a wheel outa lexan or delrin ![]() |
#14
Re: Bouncing turns
Hmm. Well, I would think wax could be a bad idea, since it could(would?) rub off easily onto the carpet, something which FIRST would not like. However, what does work, is wrapping some sort of material around the tires... |
#15
Re: Bouncing turns
we had this exact same problem last year. the cause was too much top weight and too much traction. we looked like we were convulsing while turning. we could never figure out how to stop it and just kind of lived with it. on the bright side...we never lost a pushing match. good luck!
| Disney turns away visitors on Segways | Clark Gilbert | Dean Kamen's Inventions | 8 | 19-02-2004 22:07 |
| Image Discuss: 294 Teaser, it turns? | CD47-Bot | Robot Showcase | 3 | 03-02-2003 16:56 |
| Pneumatic..Schematics..are bouncing everywhere | archiver | 2000 | 0 | 24-06-2002 00:38 |
| Bouncing heads.... | archiver | 2001 | 2 | 24-06-2002 00:14 |
| Competition Name? | archiver | 2000 | 11 | 23-06-2002 22:09 |
