#31
Re: Bouncing turns
Re: Bouncing turns
We had the same problem. What we did to solve this problem was to wrap the tire with spiral rap that is typically used to bundle wires. It has worked well for us and still gives us lots of traction in the forward direction.
#33
Re: Bouncing turns
thank you all for all the replies and ideas to help.....
we eventually tried the zip-tie idea, and it seems to help a bit (since we dont have the $$$ or time to make omni-wheels).... we can turn in place with minor bouncing, and turn along a radius with no bouncing.... we put the zip-ties on our front tires, as our bot is pretty well balanced betwen front and back, and it actually seems as if the zip-ties help us climb the step better..... thanks again! |
#34
Re: Bouncing turns
Re: Bouncing turns
but if you use zipe ties or pool vacuum hhose, you eliminate bouncing by allowing your robot to slide easily, and still not loose too much forward traction... |
| Disney turns away visitors on Segways | Clark Gilbert | Dean Kamen's Inventions | 8 | 19-02-2004 22:07 |
| Image Discuss: 294 Teaser, it turns? | CD47-Bot | Robot Showcase | 3 | 03-02-2003 16:56 |
| Pneumatic..Schematics..are bouncing everywhere | archiver | 2000 | 0 | 24-06-2002 00:38 |
| Bouncing heads.... | archiver | 2001 | 2 | 24-06-2002 00:14 |
| Competition Name? | archiver | 2000 | 11 | 23-06-2002 22:09 |
