Go to Post It's easy to get so caught up in the intensity of build that we forget we need some down time to recharge and get a fresh head. Taking a day off will only happen if you make it a priority as important as any other team meeting. Long hours do not equate to productive hours. - Greg Hainsworth [more]
Unread 22-02-2004, 19:28
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Cool USB to Serial -- Working Device Found!
On our third try with USB to Serial devices, we found one that works (in a useful amount of time)!
Device Specs:
Brand: ATEN (IOGEAR)
Model: GUC232A
Store: Best Buy
Price: ~$30
Website: http://www.iogear.com/
Computer Specs:
Operating System: MicroSoft Windows XP Home
Computer Type: Laptop
USB Version: 1
Must have CD-ROM drive for driver installation.
We plugged the device in while the CD was in the drive, the drive spun up, and it installed. We restarted. Voila, it works.
Good luck!
Unread 22-02-2004, 20:41
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: USB to Serial -- Working Device Found!
Like, You actually downloaded something? That's AWESOME!!!
Unread 22-02-2004, 21:32
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
KevinB will become famous soon enoughKevinB will become famous soon enough
Send a message via ICQ to KevinB
Have you tested this device with the Dashboard?
Unread 22-02-2004, 21:47
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Ive been using belkins one since the start with no problems...
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 22-02-2004, 21:59
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
I've been using a keyspan USB -> serial adapter hooked to an XBox since the begining as well. Works great.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 22-02-2004, 22:48
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Question: Does it work on Macs?
Unread 22-02-2004, 22:54
Linux Guy
AKA: maxdamage
Is there even an IFIloader for macos?... must..resist..the..earge..to....bash....macs!
Unread 23-02-2004, 00:44
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
We had a practice competition today in Los Angeles. Our robot and another robot controlller had problems freezing up in program mode when using a USB to series converter. We had to use the routine described in another post to unfreeze the controller.(push reset and program down at the same time.....release reset until a green light comes ......release program button.)
Unread 23-02-2004, 11:11
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Remember to make sure that the baud rate is set properly. I've got a USB>Serial by GoldX and it seems to be working fine. It's slower than a normal serial because of the conversion, but it works and that's all that counts.
The first couple tries we had with the converter didnt't work because we forgot to check the baud rate so the controller did that fun program error thing and needed a hard reset.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 23-02-2004, 11:25
D.J. Fluck
Posts: n/a
Complements of Joe Johnson,
http://www.tigerdirect.com/applicati...84-26886&Tab=0
He says it works and its only 14.99
Unread 23-02-2004, 12:56
Alpha Geek
Yeah, the keyspan adapter came from a mentor who bought it for his powerbook. Works great under Linux and OSX.
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
USB to Serial Jack Programming 24 23-12-2002 14:21
