Go to Post Read the manual. Know the manual. Love the manual. - Koko Ed [more]
Unread 16-02-2002, 23:17
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Logical statements or math formulas
As of now, we arranged our robot's code so it only contains one if... then statement, and that one came with the Default program to initialize the communication.
The rest is pure math, looks nicer to me.
But...
Which one is better? Formulas are usually shorter and take less RAM space, but what about the speed? What takes longer to process?
Anyone's thoughts?
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 16-02-2002, 23:29
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
I was the lead programmer for my team last year, and at one point, I ran out of space for new variables. So, I took the default code and stripped it down to the bare minimum cod that we intended to use. I believe that it did process faster because it simply had fewer lines of code, but other than making it much easier to look at, I don't believe it made much (if any) performance difference because I could not increase the radio communication speed, nor could I make a motor running at full speed run any faster by telling it to run at full speed more times in one second
I haven't done any voltage measurements to find out if the robot ran more efficiently or not, but any change would be negligible.
What formulas can you use? Tton General Forum 7 04-11-2003 00:33
