Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 22-02-2004, 23:40
anupalsingh anupalsingh is offline
Anupal Singh
#1219 (Iron Eagle)
anupalsingh is an unknown quantity at this point
Exclamation Beacon Sensor Problems
our beacon sensor can't find the actual beacon tower at a far distance. it only finds it at very very close distance, like 1 cm away. we even put tubes around it so the direction of the waves is in one direction instead of all over the place.
does any one know of any solution to making the becon sensor work properly?
thanx
Unread 23-02-2004, 07:11
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Beacon Sensor Problems
Did you see the update about the incorrect value of the resistor included with the beacon kit. I dont remember what to replace it with though, you will have to check on that. Also, try moving it into an open space where there isnt much for the ir to reflect off of.
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 23-02-2004, 11:54
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Rookie Year: 1998
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Do you have the beacon wired properly? The schematic that came with it is incorrect. Extremely short distance is one of the effects of the miswiring (others include excessive power draw, and overheating of components in the circuit). Check the correct schematic located here: http://kevin.org/frc/
You also might want to look at the FAQ at the same location.
Hope this helps...
Unread 23-02-2004, 13:06
Jeff McCune's Avatar
Jeff McCune Jeff McCune is offline
Alpha Geek
#0677 (The Wirestrippers)
Jeff McCune is on a distinguished road
Send a message via ICQ to Jeff McCune Send a message via AIM to Jeff McCune
We ran into this problem too. Much past 20 feet or so the tracker was horribly inaccurate. It'd find the beacon OK, but it'd be +- 10 degrees, which doesn't help things terribly much.
I completely re-wrote the tracker and receiver code and interrupt routines in order to get a 3 sensor tracker. I added a third sensor in the middle that simply stares down a bic pen tube and is completely sealed off with electical tape. Works incredibly well this way, as the tracker needs to be pointing *directly* at the beacon in order to get all three receivers to register.
I can post pictures / code if you want.
Team 677 - The Wirestrippers - Columbus School for Girls and The Ohio State University
EMAIL: mccune@ling.ohio-state.edu
...And all you touch and all you see
Is all your life will ever be...
Unread 23-02-2004, 17:14
Anupal Singh
#1219 (Iron Eagle)
yea, if u can, please post the pictures and code
and thanx a lot random dude, it probably was wired wrong, i'll give it a check.
Unread 23-02-2004, 19:02
PuiChi PuiChi is offline
Confound it!
AKA: Bernice Yau
#0840 (ART)
PuiChi is an unknown quantity at this point
same, please post the pictures. we've had some sensing problems also, but we think it's the coding.
—PCBY
aragonrobotics.org
Unread 23-02-2004, 23:37
Linux Guy
AKA: maxdamage
The way we have them coded, the trackers never stop moving. When they find it, they keep scanning untill they loose it, then they go back till they loose it the other way. We save thoes values and average them. Then we can "safely" say we know where they are. Also, the way we have them set up, they are very accurate at long range. Its nothing like firsts example, instead of the eyes like fish eyes, they are both faceing forward and are separated in the middle, this helps with accuracy.
Unread 24-02-2004, 00:04
Anupal Singh
#1219 (Iron Eagle)
yea, we have the same setup , but they can't detect properly at long ranges for some reason, but they do follow at very near distances.
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
ir beacon range doy Programming 10 29-01-2004 16:46
edu and ir beacon alan koch Robotics Education and Curriculum 4 26-01-2004 22:43
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
