Go to Post I don't think finding a way to defend the center goals is un-Gracious Professionalismistic (wow). - Sachiel7 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 23-02-2004, 01:17
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
URGENT : HOW to export .MOV w/ Cinepak/DVNTC???
Please help, i have ffinished the whole animation but one problem...when i export video from premiere 6.5 I can only do .MOV w/ uncompressed or component video....how can i do cinepak or DV/NTSC???????? We bought the latest version of quicktime pro but it does NOT help....is there something i'm doing wrong?????
thanks...
salik
Team 701
Unread 23-02-2004, 01:23
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
Rookie Year: 1999
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Re: URGENT : HOW to export .MOV w/ Cinepak/DVNTC???
give me a minute I will look at somthing
Unread 23-02-2004, 01:32
stevek's Avatar
Rookie Year: 1999
Not totally familiar with Premiere, Its been several yrs since using it last. I would think you should be able to sekect a different codec when you export and Cinepac should be ther my default.
ASSUMING YOU STILL CAN"T FIND IT THERE--
1)Save it as uncompressed Quicktime-
2)load it as a Background image in 3DS Max (I believe that in the Environment Tab of the Render Menu)
3)Render the Scene as is and save it as a Quicktime (again) but Max should definately give you the Output options that Autodesk asked for.
(Basically you use Max to recompress the footage- this is a great way if you dont have other software)
If you have Adobe AfterEffects- this could be used as well.
If you still cant do it- Reinstall Quicktime form MAX Disk
Goodluck
Unread 23-02-2004, 10:16
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Rookie Year: 2000
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
thanks...
salik
There are 2 ways to do this
In quicktime pro open up the uncompressed movie.
Go to file->export->select movie to dv stream->options->(choose NTSC)->and save
or
Go to file->export->select movie to quicktime->options->select all 3 checkmarks->seetings(video) click cinpeak, 30fps->ok->save
Unread 23-02-2004, 15:07
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Thank you....it turns out i had 6.1 which couldn't export....
