Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
Unread 23-02-2004, 18:24
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
LEDs in switch box.
We are trying to wire LED indicators into our control box that will light only when a switch is closed. We have two DPDT switches (I think that's what they are; they have six prongs) and one with just two prongs (don't know the name of that). We tried wiring the LEDs in parallel right over the switch, but (of course) that shorted the switch completely...not good. In series, they would light with the switch closed but the 5V signal never goes through (another duh! moment). I can't figure it out and I am throwing it out to the more experienced "sparkies" out there. There is probably a simple answer, but I don't know it. Thanks.
GND-------------/ SWITCH -----------------SIGNAL PIN
Where does the LED go? Is it different on the DPDT switches than the other two-prong switch? Thanks in advance.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
LED's, resistors, computers... ohm my! DanL Electrical 3 01-07-2003 09:37
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
