Go to Post remember FIRST is just an extracuricular activity in which most of the work is technichan's work...what gets you into college are good grades and a good course load...as my mom always said, "getting good grades gives you the freedom to chose to be whatever you want and go wherever you want" - abeD [more]
Unread 24-02-2004, 01:25
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Hanging only strategy?
We were originally going for the herding/hanging strategy, but our drive system sucks very very badly. We can however move from the starting point, to the side of the platform climb over it, make a 90 degree turn, climb the next level and hang on the bar. We can't really drive around on the feild for more than 30 seconds before the battery dies and the motors start over heating and the treads fall off though.
Would anyone pick us for an alliance partner if we could just do the bar? (but very consistently?!!?)
Unread 24-02-2004, 01:29
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Hanging only strategy?
hey, i suppose you are a rookie team, and atleast hanging on the bar is pretty good for a rookie team. Now, the alliance thing depends on your seed(rnaking
) and you uniqueness, i some team thinks that they want that extra 50 points they will choose you, but remember there might be other teams who can hang and herd, and lifht the 2x too, but i hope it all works out for you. And you have a splendid time at competition filled with fun.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 24-02-2004, 02:05
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Honestly, as there are well over 40 robots at every competition, I would be wary to pick one that can only perform one function.. You guys should really be troubleshooting this, if it becomes apparent that your treads won't work, maybe insert a simple 4wd drivetrain.
if your treads are falling off, put in tensioners and/or buckles to keep it in.. motors overheating? put in huge 4 in muffin fans.. i can't really help with electronics, but there's always a way to fix a bot..
example- 2000, our rookie season- our ladder was busted.. a veteran team (272) came up to us and asked why we were sitting around. They whipped us in shape and got us back up, we eventually made the semifinals. Good luck in whatever you do-
Unread 24-02-2004, 04:29
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Well, how well can you hang? 50 reliable points per match would be great for any alliance, but if your drive train problems start to prevent you from getting onto the platform, I would start making a back-up plan.
However, just being able to hang onto the bar is a very impressive accomplishment, especially in your first year. Congratulations and good luck.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 24-02-2004, 05:17
Crop-Circles's Avatar
Crop-Circles Crop-Circles is offline
The Fifth
AKA: Mike Boehl
#0066 (Flyers)
Crop-Circles has a spectacular aura aboutCrop-Circles has a spectacular aura about
Send a message via AIM to Crop-Circles
It seems to me that no more then to bots will be able to hang in any given match. It therefor may end up being a good strategy to have one robot hang almost immediatly. However, I wouldn't get my hopes up if I were you. Instead, try to get help from an experienced team when you get to you're regional. Obviously you can't rebuild your whole drivetrain at competition, but you might get it working well enough to herd balls. Never give on your robot. Last year our robot did little more the scoot around the feild, but I STILL have faith that will get it working one of these days. If you don't get into finals, use that as an opportunity to see what teams that made it are capable of, and what you need to do to make it next year.
Rule #1: Fix any and all problems with duct tape and/or zip-ties.
Rule #2: Always respect the authority of the conch.
Rule #3: Goto 20
Rule #4: Don't touch the hair.
Rule #5: (see rule #4)
Rule #6: Never call us the robotics club. We are a team, NOT a club.
Rule #7: The power of the fuzzy compels you.
Rule #8: Show EARL and CHARLIE the respect they deserve.
Rule #9: If it starts glowing, don't touch it.
Rule #10: Gracious Professionalism is a balance. Never leave home without it.
Break any of the above rules and you will be FIRED!
Unread 24-02-2004, 08:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
what if someone trys to block you from hanging, would you still be able to do it?
Unread 24-02-2004, 08:06
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
it would be EXTREMELY advisable to fix your drive train. with a drive train that only works for a limited time, there will be many cases where you are rendered immobile before you have a chance to hang. If you are a bot that can only hang, but can only do it half of the time, i would say your chances of being picked are very slim indeed.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 25-02-2004, 01:04
Kit Gerhart's Avatar
Kit Gerhart Kit Gerhart is offline
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Rookie Year: 1996
Kit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond repute
Send a message via AIM to Kit Gerhart
If you can hang very reliably, you might be a good partner for teams, but as others have suggested, you should try to fix your drive train problems. The motors heating up quickly should be fairly easy to fix. It sounds like you are overgeared. Speed is nice, but reliability is better. As far as treads falling off, is there wheel misalignment, lack of guides, or ? If you can make your drive better, you can herd balls and still hang, only more consistantly.
Good luck, and have fun at your competitions.
Team 45, TechnoKats, 1996-2002
Team 1062, The Storm, 2003
Team 233, "The Pink Team," 2004-present
The views I express here are mine, and mine alone, not those of my team, FIRST, or my previous teams.
hanging Gamer930 Rules/Strategy 7 17-01-2004 18:30
1999....look there for hanging ggoldman Technical Discussion 3 14-01-2004 12:50
A good driver makes his own strategy. What do you think? archiver 2001 26 24-06-2002 02:21
What's the best qualifying rounds strategy? Ken Leung General Forum 24 24-03-2002 18:25
This year's strategy smokescreen Rumor Mill 23 12-01-2002 19:56
