Go to Post It's not just well and good that students are being inspired, it's the whole dang point. - James1902 [more]
Unread 24-02-2004, 10:46
Jeff Zampieron Jeff Zampieron is offline
#0073 (Visioneers)
Jeff Zampieron is on a distinguished road
Send a message via AIM to Jeff Zampieron
Hot Glue/Electrical Tape
Is it legal to use hot melt glue as an electrical insulator?
For that matter, is heat shrink tube legal. The flow chart is kinda
vague.
One more: Can i use electrical tape as a marker. It could be considered
a decoration. But then its kinda functional in a round-about manner.
How about using paint for the same purpose? I can't remember anywhere in the manual about materials for marks (think like optical sensors).
Unread 24-02-2004, 12:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Hot Glue/Electrical Tape
This year (and last year) materials are legal unless specifically made illegal. Thus, heat shrink tubing is legal.
As far as hot glue as an insulator, it does act as one, but isn't sold as such, thus I doubt it would qualify as "properly insulated". However, if you were to hot glue the battery terminals, and then wrap in electrical tape, I beleive that would be acceptable.
Tape is only allowed as an electrical insulator or reflective tape used for an encoder (See the Q/A for the reflective tape). However going back to the fact that things are legal unless made illegal, paint would be legal for the same purpose. However, if you use more then $1 worth, it must be accounted for in your BOM.
Unread 24-02-2004, 12:26
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Not sure about the hot glue?
Shrink tubing is OK.
Tape as a marker is OK.
Disclaimer:
I am not an official source of answers, FIRST is. You might want to post these questions on thier questions board.
- Gene Falendysz
Unread 24-02-2004, 12:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I've always thought FIRST should have better rules regarding tape. I liked the one year where the rule was it could not be used as a structural fastener. But I think this year's tape rules are just too limiting. I understand that FIRST wants to see professional grade robots but there are several good uses of tape that I would see as illegal based on this year's rule. Examples - protecting sharp edges of metal, making tires slippery, covering bearings so carpet fibers and debris do not fall inside.
Unread 24-02-2004, 13:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
vague.
Jeff,
As an electrical guy, I would vote "no" to hot glue as an insulator. Although it seems to do a good job, it is inconsistent depending on the material and sizes involved. You have no idea, for instance, if the glue is well bonded to a surface or is merely stable because it has conformed to the outline of the part. The slightest bump will knock it off and then it's not insulating any longer.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-02-2004, 14:33
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Rookie Year: 1998
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
In regards to tape as a label:
Q: <R14> says that Electrical tape is the only adhesive-backed tape allowed and only for wire. Does this mean labels can NOT be used to identify components?
A: Adhesive backed labels are not consided tape and good wiring practices would include clear labeling of all wire
Unread 25-02-2004, 00:11
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
[edit] Sorry, I misinterpreted that. If you were planning using the tape as a marker, like something to tell you how far an arm should go out on your robot, I would use paint or a paint marker to mark that[/edit]
As for hot glue ...
In the past, the only thing I've ever used hot glue for was to help how PWM cables in place (the darn things used to pull out so easily!!) I don't think it's illegal, but to be on the safe side I would use electrical tape. If you're worried about a connection pulling through, try getting some disconnects from Molex. They work really well, and I've hardly ever had them fail.
Good luck!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 25-02-2004, 03:52
Avarik Avarik is offline
Avarik is an unknown quantity at this point
Hot glue seems to work for us, but be carefull when you use it. We got a little bit inside our speed controllers PWM port, and it caused the cable not to connect completely, making it look like the speed controller wasn't working.
The troubles that caused me this year...
The weirdest thing w/ duct tape... Matt Attallah Chit-Chat 70 11-03-2004 13:51
Reflective tape on boxes S2Taz General Forum 1 20-01-2003 17:24
How is reflective tape applied to HP crates? Dr.Bot General Forum 2 06-01-2003 15:17
HOT dishes up Animation Class archiver 2000 0 23-06-2002 22:00
Substitutes for reflective tape? Oakridege_665 Technical Discussion 1 23-01-2002 11:44
