Go to Post Pessimism and optimism are both contagious. - Taylor [more]
Unread 24-02-2004, 11:11
st28 st28 is offline
st28 is an unknown quantity at this point
Spikes?
can someone tell me how to program the spikes ????
thnx
Unread 24-02-2004, 11:17
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Spikes?
what do you want to do with them? it is quite easy.. just go into the default code under user_routines.c and find the mappings of inputs to outputs. relX_fwd set to 1 will turn the M+ output positive. relX_rev set to 1 will turn the M- output high. Zeros will make them go negative.
Unread 24-02-2004, 11:36
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Re: Spikes?
example
if you want relay one to go forward do
relay1_fwd = 1;
relay1_rev = 0;
if you want it go reverse do
relay1_fwd = 0;
relay1_rev = 1;
if you want it to go neutral do
relay1_fwd = 0;
relay1_rev = 0;
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
