Go to Post EVERYTHING in life is politics. - Amanda Morrison [more]
Unread 24-02-2004, 13:06
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Can you help us???
Can you tell us where the infered beacon will be mounted on the playing field so that we can mount the reciver on our robot in the correct location.
Unread 24-02-2004, 13:08
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Can you help us???
yes! its the little thing on the top of the assembly shown in the ball tee drawing
here:
http://www2.usfirst.org/2004comp/200...nal_LAYOUT.pdf
Unread 24-02-2004, 13:13
Thank you very much!!
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
44" above the ground.
