Go to Post The function of that part is to keep one student occupied playing with it during the entire build season. It doesn't have to be the same student all the time, they can take turns. - MrForbes [more]
Unread 24-02-2004, 13:47
BobcatProgramer BobcatProgramer is offline
AKA: Brian
FRC #0758 (Roboticats)
BobcatProgramer is an unknown quantity at this point
Send a message via MSN to BobcatProgramer
Question Looping Atonomous
I know that if you are programing a loop in the MAIN section it loops like 38ms or something but what is it when you are in the users_routins_fast section! I want to make a program in that atonomous section but I have no idea where to start because I don't know how long to make each part of it. Could someone please tell me the number of loops the fast section does a second!!
Unread 24-02-2004, 14:02
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Looping Atonomous
actually in the auton section of the user_fast code, the auton looks for new input data on each loop - so I take that as meaning, the auton code will run the same as the process_data_ from_uP loop
26.2mS per loop
unless you take that statement to look for new input out of the auton code.
Unread 24-02-2004, 14:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The "fast section" runs flat out, as quickly as it can, with occasional interruptions every 26ms or so as the "non-fast section" does some work. The number of loops per second depends on how long the routine takes to complete.
If you want to keep track of time, you can 1) use interrupts, 2) poll the PIC timer registers, or 3) use the 26ms-or-so communication as a timebase.
pic: 84's Atonomous Stack Slapper CD47-Bot Extra Discussion 2 06-04-2003 22:43
control program looping??? ctartist236 Programming 1 08-02-2002 10:09
