Go to Post there's no time like week 5 to learn programming :D - dcarr [more]
Unread 24-02-2004, 13:48
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
handling loose wires/hose/cable
With lots of extending arms and similar devices this year, I was wondering if any team has any good ideas for how to handle the loose wire that is required for full extension when the arm isn't at full extension. We are trying to use some sort of elastic system for our bar winch cable, but it needs to be replaced after every use.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 24-02-2004, 13:51
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: handling loose wires/hose/cable
We should've a couple of our long wires into a spring like piece of tubing. We had to use a lot of snot though. I think we may use a spool of sorts for cable. I didn't see isn't. But we use another spring on our cable so it is tensioned both ways. Maybe a pully with the wire attached to a spring on the side of it.
Unread 24-02-2004, 14:16
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
We use only as much slack as is necessary, make sure it's 100% clear of any possible pinch points, and wrap it with plastic spiral wrap.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 24-02-2004, 14:21
Fold em oval!
the point is that you must have significant slack when connecting something that raises to more than double its initial height.
Team 1257
Unread 24-02-2004, 15:12
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Some sort of elastic system? Please elaborate. In the past, we've used large loops held down by surgical tubing (a different sort of elastic system, perhaps), and have had no problems.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 24-02-2004, 16:53
JacobHart JacobHart is offline
#0393 (Full Metal Jackets)
JacobHart is an unknown quantity at this point
Send a message via AIM to JacobHart Send a message via Yahoo to JacobHart
Our team, 393 Full Metal Jackets, also had a similar occurance. We simply just used thin P.V.C. pipe that is light weight, and connected the tubing to the side of the arm by making braces out of thin aluminum. Cheap, effecient, and easy.
Jacob
Anyone else loose stuff? xavior06 Championship Event 20 16-04-2003 15:33
loose motors ivanslost Motors 11 18-02-2003 09:39
A New Method of Handling Nationals archiver 2001 9 24-06-2002 03:30
Goal...PVC is loose... archiver 2001 7 23-06-2002 22:38
Strict or loose interpretation? Wetzel Rules/Strategy 2 08-05-2002 20:21
