Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
Unread 24-02-2004, 16:22
FormatteD_C's Avatar
FormatteD_C FormatteD_C is offline
owned?
AKA: Matt Kerr
#1206 (Wrench Warriors)
FormatteD_C is an unknown quantity at this point
Send a message via AIM to FormatteD_C
Inverting Y axis on joystick
Hey,
We need to invert the Y axis and I don't know how I would code it, any input on this would be great.
Unread 24-02-2004, 16:25
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: Inverting Y axis on joystick
All you have to do is subtract your current value from 254. I think you can just do p1_y=254-p1_y; but just to be safe I would use a temp variable. Sooo, temp=254-p1_y; then just use temp instead of p1_y (or whatever joystick port) in your program.
Unread 24-02-2004, 16:40
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Woulden't it be temp = 255 - p1_y? Because other wise you can have negative numbers.
Unread 24-02-2004, 16:42
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If p1_y == 0, then that would evaluate to 255, which is an invalid PWM output. If you're using an unsigned data type, it can't be negative, anyway.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-02-2004, 16:47
AKA: Jamie Bliss
Oh, right. But I think the joystick vals go up to 255.
Unread 24-02-2004, 16:51
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Code:
temp = (p1_y == 255) ? 0 : (254 - p1_y);
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 24-02-2004, 16:52
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
255 is not a valid output on a PWM. I think 3 consecutive 255's result in a reset or something.
The range is 0-254, so you want:
p1_y = 254 - p1_y;
No need for a temp variable, the compiler will handle that just fine.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 24-02-2004, 16:56
AKA: Jamie Bliss
Ok, thank you for correcting me. Though I could've sworn I saw 255 on dashboard... Oh, well :shrug:
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
