Go to Post I would have bought a bigger box of popcorn and sat up higher in the stands. In the middle. - JaneYoung [more]
Unread 24-02-2004, 17:13
KWalsh KWalsh is offline
KWalsh is an unknown quantity at this point
Radio Problems
Our Operator Interface Radio says Transmit while our Robot Controller Radio says Standby, and will not receive from the OI, does anyone know why? is it a programming problem?
Unread 24-02-2004, 17:15
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: Radio Problems
No, not programming. Try tethering the bot. is your team number set to 0?
Unread 24-02-2004, 17:19
Re: Radio Problems
it works in tether fine, but the radio refuses to work, which is what we will need for the competition, agreed? We'd like to test run some before shipping it out Thursday, its crunch time
Unread 24-02-2004, 17:25
AKA: Jamie Bliss
Re: Radio Problems
It's that if the RC has one number, and the OI has another, they won't talk. You set the RC's number by tethering it. Also, if your team # is 0, it will go into Autonomous.
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
radio transmitters Arin Technical Discussion 2 18-12-2002 01:59
EduRobotics problems Ian Mackenzie Robotics Education and Curriculum 22 14-12-2002 11:33
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
