Go to Post GDC.... Come on. Counter-clockwise? ... I believe NASCAR might file a lawsuit! - Pavan Dave [more]
Unread 24-02-2004, 17:30
Jared Stofflett Jared Stofflett is offline
Jared Stofflett is an unknown quantity at this point
Send a message via AIM to Jared Stofflett
Cool pneumatics and joysticks
Here is my question. We have our robot set up to use one joystick driving, so the motors are wired to pwm13 and pwm15 My question is how would I wire and program a pair of pneumatics cylinders so that if the joystick is in the forward position both fire, if the joystick is in the left position one fires and another doesn't, and so on. My problem is I understand how to make motors move but don't understand how to make the cylinders fire based on joystick input. Also I don't know where I'd have to remap the joystick and where to put the code for the pneumatics. Appreciate any info on this.
Unread 24-02-2004, 17:45
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: pneumatics and joysticks
Well, the cylinders are controlled by relays, and the usage has been described extensively. They have 3 states: Fwd, Rev, 0.
You would need a threshold to represent at what point you fire the relays.
After you figure out relays, go ahead and shoot.
Oh, the first rule of programming: ALWAYS KNOW YOUR CODE.
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
