Go to Post The Bus includes Free Wifi and 120v Power (the bare essentials for any robotics team member) - Clinton Bolinger [more]
Unread 24-02-2004, 18:57
mpalermo81 mpalermo81 is offline
mpalermo81 is an unknown quantity at this point
Possible Robot controller problems
We've been having a problem with our robot. Whenever we try to get the control scheme working, it goes haywire. We've tried to use both the tether and the radio, yet it does the same thing both times. There are tiny spots in the axes that allow the motors to turn, but only in random directions and only until we move the stick away from that spot. We tried to reverse turning the speed controller around but that only made them turn non-stop until we moved the stick, which made them move faster. We've calibrated the wheels on the top and side of the stick. As far as i can tell we've tried everything short of re-programming the robot (which is not something we are capable, as we only have 3 team members total and none with programming knowledge).
Thanks in advance for your help.
m. palermo
team 943
Volga, SD
Unread 24-02-2004, 22:43
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Re: Possible Robot controller problems
did you try the trim tab?
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
Robot Controller Reset Problems. Joe P Electrical 8 26-04-2003 11:56
Can We Use A N64 Controller To Control The Robot pobots Electrical 25 18-04-2003 12:48
Robot Controller archiver 2000 3 23-06-2002 22:54
