Go to Post MAKE SURE THE BATTERY DOES NOT FALL OUT - magnets [more]
Unread 25-02-2004, 15:50
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Problems with MPLAB
Originally Posted by Paradox1350
I'm on Charley's team. We have not tried reinstalling. We lost the disc that came with the EDU bot kit and transfered the files from one computer to the laptop that we have. The program works on the original computer, but not the laptop. I have no idea whether or not we are missing the C18 compiler.
There are changes that the installer makes to your PATH environment environment variable. You need to set it the same way that the computer it is working on is set to. To access the path, open a run box and type "msconfg". Hope that helps. If you need more help with modifying the PATH post.
Unread 25-02-2004, 16:09
Jared Stofflett Jared Stofflett is offline
Jared Stofflett is an unknown quantity at this point
Send a message via AIM to Jared Stofflett
Just to add to all this I tried running the newest version of the ide off the web sight on xp and it didn't work, the version that shipped with the kit worked. Something with either version 6.31 or 6.4 not working with nt based opperating systems.
Unread 25-02-2004, 16:12
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
6.3 works fine on XP and 2k. I don't think it's the version.
ps- is there a diference?
Unread 25-02-2004, 16:41
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Several of the schools I'm working with are using MPLAB 6.4 on XP systems.
There must be some other little quirks, like OS patch level, involved.
Unread 25-02-2004, 17:25
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
find autoexec.bat, and add the following lines to it:
set PATH="C:\mcc18\bin;%PATH%"
set PATH="C:\mcc18\mpasm;%PATH%"
set MCC_INCLUDE="C:\mcc18\h;%MCC_INCLUDE%"
(change the paths to match your copy of mcc18, of course)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 25-02-2004, 18:13
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Yes, this is a problem with PATH. I wanted to post from school earlier today, but for some reason I could not By the way, XP/2000 will ignore autoexec.bat by default. You change these values in Control panel>system>Advanced>Environment variables
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
Im Having Problems With Mplab!!!! hedgehogger Programming 2 20-01-2004 17:43
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
