Go to Post Cooperate BEHIND the curtain; compete IN FRONT OF it. - Travis Hoffman [more]
Unread 17-02-2002, 21:30
punarhero's Avatar
punarhero punarhero is offline
#0696 (Clark Magnet Robotics)
punarhero is an unknown quantity at this point
Send a message via AIM to punarhero Send a message via Yahoo to punarhero
Fuse Panels
Hi,
I need an answer IMMEDIATELY
Please tell me if we can have a fuse panel hooked up to another fuse panel. Please don't guess because someone told us that we can't, but we are sure we can.
Tell me if u know
Unread 17-02-2002, 21:53
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I guess you can't be serious about hooking them up in serial...
You can hook them up in parallel. Just wire the breaker into the fuse panel. Then from the fuse panel into the other one. You can do that...
Unread 17-02-2002, 22:01
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
2 separate feeds from the 60A looks OK
Why would you want the fuse panels daisy chained from each other instead of a multiple feed from the 60A breaker to each?
Which appears to be legal.
All the rules state 'fuse panels' which means multiple fuse panels
Unread 17-02-2002, 22:39
punarhero's Avatar
we meant is it ok to hook the fuse panels up in parallel?
Unread 18-02-2002, 07:42
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
It is legal to hook them up in parallel - which means that you can run separate wires from the battery to each panel.
Do not, however, wire two fuses in parallel! You could damage whatever you are trying to protect with the fuse, or even start a fire. Aside from that, it's against the rules.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 18-02-2002, 10:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
We use two fuse panels.(Have for all years that there were two available.) We do not run seperate wires from the battery to each but #6 to the 12 way and another #6 to the 6 way.(+ and ground) Try and make your high current devices all on the 12 way or at least as many as possible to minimize the current in the longer run. Less current=less voltage drop on longer wire runs. Follow the color codes and other wiring conventions and make sure all the hardware is TIGHT.
Have fun and good luck.
Al
WB9UVJ
www.wildstang.org
________________________
Where to Buy 40-Amp Fuse Panels? yangotang Electrical 9 11-11-2003 18:44
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
What teams have cool control panels? Ragin_Kage Robot Showcase 1 09-05-2002 17:43
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
