Go to Post FIRST - Breaking stereotypes everywhere - Sparks333 [more]
Unread 24-02-2004, 23:44
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
WHich motor to lift and for arm
hey,
how powerful is the Denso-Window motor, and which motor do you guys think of the most strong one. Can a single Window Motor lift the whole robot up(130 lbs), if no than which one can. I know this is a lat to be asking this.
We had a mechasim that uses a single window motor to move an pivoted arm, with a light grabber, but when we hold on the ball the thing wont go up. But it works pretty good when not holding on ball. Also the arm is about 56 inch, but if we put the ball at about 30 inch it work okay. THe arm is mounted on a 60 teeth sprocket(drilled through and bolted) the window motor has a 20 sprocket so basically a 3:1 ratio. Any comments to help us on this, fast replies will be appreciated.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 24-02-2004, 23:46
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: WHich motor to lift and for arm
Out of the box, the van door motor has the most torque. I'd recommend trying to get a smaller sprocket, such as a 10 tooth, so you can get even more torque for your arm.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 24-02-2004, 23:49
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
Team Role: Coach
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
van door to lift, denso/window the manipulate the grabber.
rest of it = drivetrain
Woburn Robotics, Class of 2005.
Unread 25-02-2004, 00:05
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
will we need a ratchet on the van door?
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 25-02-2004, 00:58
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Yes you will. Or some other device to stop it from backdriving and blowing its worm gear.
Unread 25-02-2004, 01:03
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Our will stop without the ratchet. We will probably add one anyways though. Our winch diameter is <5/8" though. Small diameter helps.
Unread 25-02-2004, 10:16
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Ours is exactly 5/8" and a combination of that and the adjustment screw and the van door motor doesn't back drive. It all depends on how fast you want to go, how much energy you want to use, and how complex you want your system to be.
Unread 25-02-2004, 10:20
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
our winch is directly connected to the drive train, so we have 2 drills and 2 fischer prices running it. those have more power than the van door, but stealing power from the wheels requires a lot of planning and is probably not something you can add on at this point
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 25-02-2004, 10:34
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I would suggest that you look in the White Papers technical section for the papers on motor selection. Ken Leung has done a nice job of compiling info from Joe Johnson and others that will let you select a motor and gear ratios to keep from smoking motors. The key is determinig the Power you need first and then adjusting the motors to get the required torque.
The examples can be used as 'recipes' for lifting balls and robots. We used these notes this past year to select dual Fisher Price gearboxes to lift twice the weight of our robot straight up in under 10 seconds. We have not tested the twice the weight yet but it gives us a good safety factor.
Andy Brockway
Team 716, The Who'sCTEKS
