Wiring "3-pin" Shaft Encoder.
Hey everyone. We ordered a few of these shaft encoders from http://www.newark.com and are having a heck of a time trying to figure out how they should be properly wired. Does anyone have suggestions or experience with this unusual encoder?
Re: Wiring "3-pin" Shaft Encoder.
It looks like it's a quadrature encoder with the quad signals on A & B, power on C. I'll have to verify with another electrician in the morning to see if he's had personal experience with this model before. |
You should be able to connect A/B to signal as you are doing and C to ground. Then the digital input will be high when there is no circuit and low when signal is passed through the encoder to ground. |
Actually the pull-ups are internal to the PIC. You can disable them using a register.
But yeah, try connecting C to ground. It should work then. [Edit] Hm.. looks like I'm a bit too slow. |
-Kevin |
That encoder advertises a life of 100,000 cycles. I think it is designed to be an electronic knob, and connecting it to a spinning shaft might rack up the cycles pretty fast.
On the other hand, it doesn't have to work for ten years. ![]() |
| Problem with 5/8 in. shaft in this years kit | echos | Kit & Additional Hardware | 5 | 14-01-2004 21:21 |
| Need Help on Shaft Mounting... | archiver | 2001 | 3 | 23-06-2002 23:29 |
