Go to Post Values aren't really dictated, they are created by everyone involved. - Herodotus [more]
Unread 25-02-2004, 12:29
KWalsh KWalsh is offline
KWalsh is an unknown quantity at this point
More Programming Blunders...
The Solenoid Valves are not programmed correctly, because the lights on the Spike Relays are red instead of green, can someone inform me on how to make our three solenoid valves to work by modifying the default program?
Unread 25-02-2004, 12:45
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: More Programming Blunders...
the aliases for relayX_fwd and relayX_rev correspond correctly to the labels on the spikes, but not the lights - in fact, the labels were printed wrong, so IFI changed the aliases in the default code so that the labels would be correct. Thus, you will see red when M+ has power, and green when M- has power.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 25-02-2004, 14:30
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The latest re-release of the default code from IFI corrects this problem. You just need to copy the latest ifi_aliases.h file into your project.
See http://www.innovationfirst.com/FIRST...umentation.htm
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
