Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Unread 25-02-2004, 14:09
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Infrared Beacon and Sensor Diagnostics Code Released
I've written some code that I hope will help teams diagnose infrared beacon and sensor problems. Running on the FRC-RC, the code will send to the console window a dump of all raw data generated by the receiver code every two seconds. The zipped file, frc_diagnostics.zip, can be found here.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 25-02-2004, 16:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: Infrared Beacon and Sensor Diagnostics Code Released
Thanks, Kevin. I'm sure there will be many appreciative teams out there. Thanks for all your code contributions.
Unread 25-02-2004, 17:37
FRC #2429
Thanks. It's really cool knowing that a few thousand people have looked at my (and Rich Petras') code and maybe learned something by it. I've had many great e-mail and IM exchanges with students who clearly understand how this stuff works and wanted to learn more about topics like control theory and digital signal processing. Inspiring HS students to want to learn more about cool stuff like this is one of the many reasons I really, really dig FIRST.
-Kevin
Kevin Watson
http://kevin.org
Unread 25-02-2004, 17:50
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Can you make general debug code? Like last night, I could have used something that told me about the analog ins.
It doesn't need to be complex, just use the printf and a structure like this:
PortType_## Value
DigI 1-18 0-1
DigO 1-18 0-1
AnaI 1-16 0-1
Rly 1-8 -1-1
Pwm 1-16 0-255 (Just in case)
Making a VB prog to read them would be easy. Heck, I could do it tomarrow . Well, a little later.
IR senors detect pulses for 360 degrees Chaychay Technical Discussion 6 15-02-2004 15:06
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
ir beacon range doy Programming 10 29-01-2004 16:46
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
edu and ir beacon alan koch Robotics Education and Curriculum 4 26-01-2004 22:43
