Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 25-02-2004, 17:52
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Can you help us?
We would like to know just how much of the robot has to be shipped away. Can we keep the control unit so that we can test programming or does all that have to be done prior to shipping? Also once it has been inspected it can exspand to any size right? thanks!!
Unread 25-02-2004, 17:58
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Can you help us?
From the Q&A:
Q: Can we keep the victor 884, controller, spike relay, and fuse boxes when we ship the robot?
A: No. You may keep your driver controls, the OI and power supply, the OI radio, the RC, and the RC radio.
No, this is incorrect. Your robot must be no larger than 30"x36"x60" at the start of any match on the field. It must be able to maintain this shape on it's own (can't lean against anything). Only after the match has begun are you allowed to expand to be larger than this size.
Unread 25-02-2004, 17:59
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Rookie Year: 2000
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
All of the robot must be shipped except the radio, robot controllers, and operator interface.
As to expand your robot must start within the box every time it is on the field, not just after it is inspected. Once the match begins your robot can get as large as you want.
Unread 25-02-2004, 18:03
Can you help us?
Can we ship a robot and then when we get there add stuff to it or does it have to stay as it is when it is shipped???
Unread 25-02-2004, 18:08
Alavinus's Avatar
AKA: Andrew LaVinus
Rookie Year: 2000
You can do anything to your robot in the pit, even build an entire new one, as long as you DO NOT make any new parts after the ship date. You may bring all the raw matierials you like, but you can not build another component, bring it and bolt it on. You may design it before but then build it once the pit opens on Thursday.
