making speed controller digital
Is it possible to wire a speed controller to a digital output. I want to put one of my motors on one of the the digital switches of the joystick and don't need to control speed. Thanks in advance
It's not possible to wire a speed controller to a digital output, but it is possible to create 'digital control' of a speed controller.
For a very nice explaination and complete software, go here at innovationfirst.com. |
Yeah, if you don't want the motor going full power when you press the button, you can also just say
if p1_sw_trig = 1 then PWM12 = 150 or something like that. Otherwise just use a spike. |
If p1_sw_trig = 1 then (Goto) is implied If p1_sw_trig = 0 then skip: PWM12 = 150 skip: that would be one way to work around that problem. (Similar to how the PWM limit switches are programed) |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| How do you connect the speed controller fans? | Iain | Electrical | 7 | 31-01-2003 07:05 |
| Speed controller fan replacement | Rickertsen2 | Electrical | 11 | 16-01-2003 08:46 |
| Speed Controller Limits | yaman | Technical Discussion | 11 | 15-01-2003 18:40 |
| Ugh...PWM pin vs. Speed Controller | archiver | 2001 | 1 | 24-06-2002 00:27 |
