Go to Post FIRST will continue searching for rules and procedures to keep us from hurting ourselves. However, none of this will substitute for judicious application of common sense. - Richard Wallace [more]
Unread 18-02-2002, 00:13
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Weight Distribution Question
Which wheel in the attached drawing bears a greater percentage of the weight of the box? I'm thinking it's A, but I want some support from my friends on this one.
Thanks,
Eric.
Unread 18-02-2002, 00:32
Brian Savitt's Avatar
Brian Savitt Brian Savitt is offline
#0056 (ROBBE Xtreme)
Brian Savitt will become famous soon enoughBrian Savitt will become famous soon enough
Send a message via AIM to Brian Savitt
I would have to say wheel A because the weight is tipped back onto that wheel (A)
Hope I helped
Brian
Unread 18-02-2002, 00:44
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
A is the correct answer. More of the box is closer to, outside of, wheel A.
Viva Olancho!
Unread 18-02-2002, 06:13
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
The answer cannot be determined from the information given because you have not specified the location of the center of mass.
Leo M.
Unread 18-02-2002, 07:37
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
If you assume that the CG is in the center of the box, and that the box is at rest, wheel A will support more of the weight. You can do a quick free-body diagram to proove it to yourself. (See attached)
Notice that the forces balance, which is probably what your friends were thinking. But when you include the torques in the equation, the ground has to push on wheel a more than wheel b to keep the box from tipping.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 18-02-2002, 08:23
Eventually you get the equations:
Fa = W/(1 + Ra/Rb)
and
Fb = W/(1 + Rb/Ra)
and it is unnecessary to make any assumptions about the location of the CG, other than that it lies between the wheels.
Substitute the distances Ra and Rb into the above equations, and out pops the force distribution on the wheels.
If we further assume that the wheels are a distance "L" apart,
and the CG is a distance "H" above the line of the axles and centered between them (with the body horizontal), and the body makes an angle A with horizontal, then we have for Ra and Rb :
Ra = ((L/2) - H tanA) cosA, and
Rb = ((L/2) + H tanA) cosA.
(Check behind me - I did this quickly on scrap paper.)
Now you only need to know how wide the robot is, how high above the axles the CG is (good luck, but try to estimate), and what angle the body makes with the floor, and you can calculate the weight distribution. If the CG is not centered, the geometry is a little more complicated, but not that bad.
Leo M.
Unread 18-02-2002, 18:34
I am somebody now!
Thank you all for your help. The CG was not particularly relevent because we are simply trying to shift more weight from the 'B' wheel to the 'A' wheel based on, um, field tests
Thanks again,
Eric.
Unread 19-02-2002, 06:08
I know what you mean - a lot of times all the calculations in the world can't do as much a a quick whack with the hammer.
Leo M.
weight distribution? chrisw Technical Discussion 3 11-01-2003 13:25
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
