Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
Unread 26-02-2004, 09:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Exclamation Why I hate c
Code:
void User_Autonomous_Code(void)
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
        // [state machine implementation]
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
    Process_Data_From_Local_IO;
It took me four hours last night to figure out why Process_Data_From_Local_IO never gets called.
I Hate It When... sanddrag Chit-Chat 77 25-12-2003 10:57
I hate the BCS and i really ha te KANSAS ST. Jon Reese Chit-Chat 10 11-12-2003 12:09
GRRr.... I hate webpages... XRaVeNX Chit-Chat 4 15-03-2002 12:28
Why I hate Logic EnderofDragon Chit-Chat 2 19-02-2002 21:02
