Go to Post ...too much to do... ...too little time... - Joe Johnson [more]
Unread 26-02-2004, 15:22
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 219
Unread 26-02-2004, 15:26
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
Re: pic: Team 219
Heck yeah baby, 6 weeks paid off. She looks better now, we have all of the sponsors and the flapper on, plus there are a few weights in the front. After nailing down a few problems, we are running 100%, now all we have to do is calibrate the banners at the regional and we're good to go. See all of you in Trenton
Good luck
Marcus - Team Impact 219
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 26-02-2004, 15:35
ErichKeane ErichKeane is offline
FRC #3210
ErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really niceErichKeane is just really nice
Send a message via AIM to ErichKeane
Post Re: pic: Team 219
That it did marcus, that it did.
Id like to explain a few things, as to what our robot accomplishes. First, The flapper. In that space with the window motor, a piece of PVC comes accross with rubber flaps on it, used to force balls into the front bin. It can be reversed to send the balls back out.
Second, auto control. On the 1 side, there are 3 banner sensors, which are used simply to guide the robot up to our ball. The Cylinder you can see at the top (back) of the robot, with a delrin pad on it, with the radio attached to its mount, is used to poke the ball off its stand.
Third, the center wheels are on cylinders. They are forced down, lifting the (back) of the robot off the ground, placing the rear wheels (non cage end) on the step, then brought back up, therefore dragging us up the steps.
Finally, how we hang: The Pole with the hook on the end resembles a car antenna, with a forced pipe pushed up the center, which lifts the hook to the level of the bar. Then, the antenna is pulled back, leaving the hook on the bar, attached to the robot with aircraft cable. The Winch, as you can see, is used to pull the robot up, at a very high rate of speed.
That is really us, we skipped the 2x ball because we figured everyone would try, and it did not fit our team personallity well.
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
