Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 18-02-2002, 08:52
Dreistul Dreistul is offline
#0440 (Huskies)
Dreistul is an unknown quantity at this point
Send a message via AIM to Dreistul
Zone Arm damage
Here's a question about the zone arms that other threads are discussing:
If a opponent robot has a zone arm extended and it's blocking the movement of your robot or the goal (not entangled in either), if you move your robot through their arm and damage their arm, would you be disqualified for damaging the other robot, or will the judge overlook it as a bad design on their part? The robot (ALL of the robot) is supposed to be designed to take some abuse; standard pushing and shoving doesn't seem like a malicious act, even if it's done a flimsily designed zone arm.
Other thoughts?
Picture of robot starting zone? Jeff Rodriguez General Forum 2 06-01-2003 22:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
