Go to Post We don't build robots because it's easy, we do it because it's hard. Maybe we can work on giving new members a warmer and gentler welcome, because it's hard ;). - Winged Globe [more]
Unread 18-02-2002, 09:36
tareyton
Posts: n/a
Pressure gage on receivers
Does anyone know if we must have the pressure gage installed on the tanks (Receivers) is this a required element? What if this gage breaks Ours reads 160 when the compressor cuts off I know this has to be wrong. Will we get nailed for this at inspection.
Unread 18-02-2002, 14:09
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
You must have the NORGEN pressure regulator as the first thing in the loop before the solenoids.
Unread 18-02-2002, 21:14
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Pneumatics Manual says 'The gauge may be placed ...(on the Norgren regulator)', but what that word 'MAY' means to First this year may be a mystery.
Last year, we were called once for no gauge, but may was taken as permitting, not requiring, and we _were_ allowed to compete. And at the Nats, there was no notice taken of the lack of gauge.
We did have to produce a gauge and temporarily attach it to prove that the pressure downstream from the regulator was proper.
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
