Re: Looking back I would change...
Joe, did you have any problems controlling the drives with this unit? As a typical planetary gear system the backlash is typically what most software guys complain about. Was the controllability of the drives at a high enough resolution? Adding encoders to this unit wouldn't seem to help it much becuase of that slop in the gear system. Thanks Joe. Ellery |
Re: Team 47... Alchemists...
There is some backlash, but to be honest, it is not all that much. With #35 Chain, it was often on the order of magnitude of our chain slack (if we let it get loose, which we did from time to time).
But, yes, the additional backlash can cause some problems for control loops at times. It is not that bad though. We ended up either living with the oscillations or adding damping to the system. The only joint we took steps to do something about were are fingers -- they are over powered and very lightly damped. We actually used some set screws on our finger axles, not to transfer torque (which everyone knows sucks) but to add drag to our pivots so that the extra damping removed the oscillations -- not exactly elegant but it worked. Joe J. |
I saw the "magic" in Atlanta and was very impressed. I'm just wondering how long until you have that whitepaper out? I understand you're busy (aren't we all)... but I'm eager to learn more. Thanks in Advance, John |
If I start to list the things I have going I will sound like a whiner so I will just leave it at that... ...I want to do it... I think I will just have to get some pictures taken by one of our students. That should help me get the ball rolling. Time will tell. Joe J. |
Joe J. |
| Am I the only person with this job? | A. Leese | General Forum | 55 | 22-06-2006 20:10 |
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| Shelf Life Of A Team | Vin211 | General Forum | 21 | 07-01-2004 22:31 |
| Info for starting a new team (again, I'm sure) | archiver | 2000 | 3 | 24-06-2002 00:24 |
