Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 29-02-2004, 15:30
Guest
Posts: n/a
Recording Official FIRST Footage
Dr Bot started a thread regarding webcasting regionals. I just want to tape the footage directly on VCR or DVD? What equipment do you need? And, what do you need to do?
I need to know how I'm supposed to setup a connection with the FIRST cameras at the regional. I'll be at the Pacific NW Regional, so if anyone wants to help us with it, look for team 948.
Unread 29-02-2004, 16:27
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Recording Official FIRST Footage
This is going to be a MUCH trickier issue. I'm not certain FIRST will want you just recording the footage for your own purposes. You'll need to get permission from the Regional Coordinator and probably from someone higher up in the FIRST hierarchy.
In order to do this, you'd just need your VCR, and then the A/V crew at the regional would hook it into their distribution system. I'm thinking this won't be allowed, because many, many teams would then want to do this, and the A/V crew can only handle so much work.
That being said, I can only suggest emailling around on the FIRST Contact list and maybe asking on the Q&A to see if you get an answer.
Unread 29-02-2004, 16:48
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Rookie Year: 1999
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Talk to the media coordinator as well as your regional director. When I worked at the Media Tent at Nats in 00 - 02, we were allowing a team-designated videographer/photographer to get in a special area near the field to tape for their matches only. I dont remember if the A/V hookups were there and allowed to be used by teams.
Good luck!
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 29-02-2004, 16:56
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
When you are at your regional, i would suggest asking the pit administrator if they know if there are Breakout (Multi) Boxes for Audio/Video present. These are used for recording the event. Normally they have enough extra ports where a team may beable to connect a vcr to tape their match, but only their matches. If you plan to tape a match from FIRST equiptment, i would reccommend to bring your own vcr(s), connectors and cables and blank video tapes.
-Michael Dessingue
Unread 29-02-2004, 17:22
Rookie Year: 1998
I stand corrected, it appears that there are setups to allow you to do this. I was just thinking from and AV standpoint. If all the teams recorded all the competition, you'd need a 30-50 output DA for all the teams, and that'd be a bit pricey and not something the AV people would be likely to have.
As far as an RCA splitter, I wouldn't reccomend doing that unless it's an absolute last ditch measure. Splitting the video signal like that will significantly degrade the signal quality for both teams. The same goes for looping through VCR outputs, just not as much. The signal quality will drop a little for each pass-through. You can get a cheap Distribution Amplifier from radio shack that will do a much better job of splitting the signal. Just check with the AV people before plugging it in, as you might cause a ground feedback loop and put a 60Hz hum in the audio and video for the entire event.
Unread 29-02-2004, 17:50
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Rookie Year: 2000
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Actually it really doesn't. In UTC 2002 I remember there was a bunch of VCR's that were series attached to on another and there wasn't any signal degradation that I noticed on my tape. Unless of course there are cruddy wires that are present in the series of VCRs.
I have used a RCA splitter for a while now, (2+ years) and have not seen any degradation of either the audio or the video signal.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 29-02-2004, 16:46
GET IT ON!!
Rookie Year: 2000
Just ask for the black box. The black box is a device where it converts HD (High Def) FIRST footage into SD (Standard Def). It is usually a table where you can plug in your VCR via RCA. You must supply your own VCR cables.
There is some limitations though
They usually only supply mono and not stereo sound.
They go the full 4:3 ratio and not just TV safe area (meaning that scoreboard will probably be cut off a little)
One thing though is to bring an RCA splitter, sometimes there are not enough jacks to hook up your VCR. And don't depend on just hooking into someone else VCR's output, they might take it out earlier than you want it.
Regarding the last post, there is no issue that I know of permission to use the official feed. FIRST gives you the tools to do so, and they never specified any restrictions on it.
Rhode Warriors
Unread 29-02-2004, 17:36
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
I'm confused...the impression that I got from the original post was that he (she?) wanted to record the streaming footage from their PC to a tape or a DVD. All of the replies thus far have been how to get the footage at the regional BEFORE it's sent out via the Internet.
Which is it?
Unread 29-02-2004, 21:42
Guest
Posts: n/a
No, I want to directly get footage from FIRST at the event itself. Not through the internet.
Unread 29-02-2004, 21:56
Rookie Year: 1998
RCA splitters do degrade the signal. They attenuate the signal by around 4dB for every split, and you can only do that so many times before the low signal makes the video look bad. I'd think the video would look dimmer and noisier after just two splits.
As for stringing VCRs in series, well I can only speak from technical knowledge/assumption there. I'm pretty sure the passthrough circuity isn't perfect in any VCR, since they're not terribly expensive. So if you string 10 or 20 of them together, I don't think the last one will look quite the same as the first.
Unread 29-02-2004, 22:05
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
If you want to get high-end equipment I would suggest asking your local Public Access TV station. I know that we have a few $10,000 cameras and about 5 Cannon GL2 (a near broadcast quality camera)
The views expressed in my posts are Mine and mine only.
my myspace!
NJ team 41 would like to test on official surface Smrtman5 General Forum 1 16-02-2004 19:07
Video footage of match 119 on Galileo archiver 2001 6 24-06-2002 03:36
It's official archiver 1999 1 23-06-2002 22:03
2001 competition footage JasonS General Forum 3 13-02-2002 23:05
2001 competition footage JasonS General Forum 1 13-02-2002 11:43
